Ring context not attached. The hardware ring configuration, as a result, fails
Check the ring that is being passed using 'show erps <ring>' command. Validate the ring. If problem occurs again, report to technical support as a software fault.
Error
Failed to attach the ring context. Null ring pointer for ring Id %ringId% context%context%
| Name | Type |
| ringId | uInt32 |
| context | uInt32 |
